TA intake gasket for aluminum heads .062 thick $23.00 shipped . rjc header gasket works best with ported R heads will also work with stock great sealing gasket $50.00 shipped , remflex header gasket great gasket will work with steel or aluminum heads $36.00 shipped reflex turbo 3 bolt up pipe gasket $18.00 shipped, trans mount not that old & trans crossmember to frame used ok condition $22.00 shipped turbo cover for external wastegate ok condition $25.00 shipped. cam sensor good shape with rjc kit installed on the ring $80.00 shipped.
