I have the TA Performance Stock Replacement Headers, and the driver's side header is interfering with the collar on the joint on the steering shaft. The apex of the bend in the #5 tube aligns exactly with the collar and is causing it to rub. I need to move the shaft slightly up and to toward the driver's side. If I loosen the steering column-to-firewall bolts, how much should I be able to adjust the column?
Thx,
Dave
Thx,
Dave
