I am going to pull my OEM headers and attempt repair an exhaust leak. Not sure if they cracked or just started leaking. Previous owner put a gasket to the head. I might try to run without a gasket and hope nothing is warped. Are there gaskets to the Y-pipe? Or metal to metal there too?
If I remember correctly the heat shields are tack welded to the headers. If the headers need welding, do you guys reinstall the heat shield afterwords?
