Headlight Upgrade
Can Move has these on his car! They look awesome!!
It's on the list... but what I am unsure of. I do have Kirban's headlight kit... It's slightly, better.... But it was never going to be a keeper.
Any thoughts on any of these???
http://www.carid.com/1987-buick-regal-headlights/
I do have the LED tailights and am going to do the parking lights at some point as well.
If you get any of these post up some pics interested in the Spec-D® - 4x6" Rectangular Black Projector Headlights Item # 55925089 , I have blacked out all the lights and I think this might top it off.
Can move has this headlight. I'm not sure what's on the attached link is the same?????
Yes I have seen his lights.... They look great. Sorry for the delayed response. I had trouble getting on and have been busy. Anything that I end up doing I will definitely post up.
JW Speaker Evolution 8800's (Hi's and Low's) with black bezels - 4" x 6" LED's
Personally I think you should go with the kit from Kirban Performance. You can then purchase an awesome LED kit. I've heard good things about briteassleds.com H4 bulbs. This is the set up I'm planning to buy when I get my bonus check in 2 months.
The original headlights are what give it the menacing look. I'm not fond of those aftermarket looking ones like in the picture above. Makes the car look JDM.
For now that is the plan... But was also thinking down the line. Being these lights are expensive it depends... I don't want the JDM look, even if I change to the crystal looking ones with a bulb setup.
The lows look so bright! Think they might blind oncoming traffic?
They are bright but not offensive to oncoming traffic. The cut off is very wide & flat and defined. It is clearly a sharp and crisp cut off that is the about the best I have ever seen.
The LED projectors are known for not glaring into oncoming traffic (provided they are aimed correctly), which these are.
Not an inexpensive light, but quality doesn't come cheap. These are used in emergency vehicles like ambulances and fire trucks and are Made in the USA, not China, so the quality is A1.
Here is a shot from in my garage with the car about 2ft from the wall. Driver side headlight is the JW Speaker Low beam, vs the passenger side which is Hella E Code H4 with Phillips D2S 4300K HID with anti glare shield.
Notice how well defined the cut off is.
When I upgraded my aircraft landing lights to LED's, I too was impressed. I could see things all the way to the other end of a 6500 ft runway. Very little current draw and the cutoff was crisp and defined. I know an airplane ain't a car, but the principle is the same.
