Thanks for the compliment........these are the black housings.
Very easy to install. No different than installing a replacement sealed beam headlamp.
The headlight housing is removed (4 screws) and the head light trim rings removed , headlights unplugged and these are installed in the reverse order and plug directly into the factory wiring. No wiring harness with extra relays or fuses required as these draw very little power at only 2.25 amps each. A true plug N play installation.
Will take you less than 10 minutes for outstanding light output. I now look forward to night driving! LOL
