Headlight Upgrade
Here's a picture of the front end with all 4 installed.
How hard was it to get them installed/mounted. Are those with the chrome face housing or the black face housing? They look good!!!
Thanks for the compliment........these are the black housings.
Very easy to install. No different than installing a replacement sealed beam headlamp.
The headlight housing is removed (4 screws) and the head light trim rings removed , headlights unplugged and these are installed in the reverse order and plug directly into the factory wiring. No wiring harness with extra relays or fuses required as these draw very little power at only 2.25 amps each. A true plug N play installation.
Will take you less than 10 minutes for outstanding light output. I now look forward to night driving! LOL
I like them! ;) Did you buy them directly from JW or some other seller? I also like what you said about having no wires to cut! (y) I saw on their website that you can get them with either a chrome or black bezel...which ones are yours?
I also like these: http://www.truck-lite.com/webapp/wc...0001&storeId=10001&productId=119543&langId=-1 but it's hard to compare them with the JW's unless you can see them side-by-side...:rolleyes:
Claude.
