headlight ?
turbobooster
this is may be a stupid question but here it goes i just noticed it the other day i had my regular headlights on and clicked back the turn signal lever for my highlights wen the high beams go on the low beams come off my question is are the low beams suppose to stay on while i hit the high beams ? or should the low beams stay on as well wen i turn on the high beams?
so even though the low beams only turn off wen i hit the high beams and then turn back on wen i turn off the high beams i can still have a bad headlight switch?
so something is definitely wrong with my lights then all the lights work fine except for that small problem
