Yes, ARE (Agostino) is in Canada, and his stroked and sprayed WS6 is the fastest LS1 I know of at this time.
And I also know of 3 10 sec N/A LS1s that are streetable, and there could be more. The bottle/turbo/charger isn’t the only way to go fast in an LS1
Stephen Sanders is running 10.03 N/A with a MTI 422ci LS1 in a ’00 Z28 that is on the verge of being the first into the 9’s N/A any day now. That is the most impressive LS1 I know of. His race weight is only 3200lbs though...
As for running spray in a 6-speed…If you get a “window” or “rpm” activated switch you won’t over-rev on the spray. This switch cuts the juice on and off at preset rpms so you won’t be spraying past a certain rpm (have it cut off a few hundred rpm before limiter), or at too early an rpm (before you're supplying enough fuel). Anyone spraying a 6-speed would be crazy not to have one.
