something to check
had a similar problem one day the ac fine the next no cold air , turned out to be the slider under the dash that opens the air bypass for the ac, I was able to access mine through the glove box. it should be just to the left you'll see the slider cable attached to it. Mine was cracked off from years of use, something worth checking...
