heated 02 kit, TPS booster, inside window felts, 30# injectors
87geeinn
Buick and AMG pilot
30# injectors with about 10K miles on them. Good as stock replacements and can use stock chip: $100 shipped
inside window felts (pair)--new from GM still in box: $50 shipped
Used heated 02 sensor kit: $50 shipped NOTE: The sensor itself gave funny 02 readings on Scanmaster as it is a very active sensor. Went back to ol' school 02 sensor
Used TPS voltage booster: $50 shipped NOTE: This thing is handy to calibrate your TPS if you don't have a scantool or you can't achieve the max readings at WOT with your sensor. Won't improve performance IMO.
Will take pictures if necessary.
