Feb 22, 2014 #1 B bpman1234 Well-Known Member Joined Jan 24, 2011 Messages 2,001 ''high'' again. just want to know if i can get a replacement 4 wire heated o2 from the local parts stores and what would be the part number ? thanks .
Feb 22, 2014 #2 R RmvBfrFlght Well-Known Member Joined Sep 28, 2007 Messages 2,234 AC Delco AFS-75. IIRC, it was used on LT1 equipped cars. RemoveBeforeFlight
Feb 22, 2014 #3 B bpman1234 Well-Known Member Joined Jan 24, 2011 Messages 2,001 ok thanks for your reply RmvBfrFlght. i looked atnthat the plug is different
Feb 22, 2014 #4 T TURBOPOWERED68 David Joined Jan 31, 2006 Messages 8,819 bpman1234 said: ok thanks for your reply RmvBfrFlght. i looked atnthat the plug is different Click to expand... i need one too but with the square plug
Feb 22, 2014 #5 B bpman1234 Well-Known Member Joined Jan 24, 2011 Messages 2,001 iwas looking at that site and i think its the afs-109 it has the right square plug correct me if iam wrong ,please .
Feb 22, 2014 #6 B bpman1234 Well-Known Member Joined Jan 24, 2011 Messages 2,001 ACDelco AFS109 Oxygen Sensor.amazon
Feb 23, 2014 #7 H HouTX87 Active Member Joined Nov 21, 2011 Messages 837 acdelco AFS 109 is what I'm using. Caspers kit says afs 109 or similar. http://www.casperselectronics.com/store2/product_info.php?products_id=1082
