Heater Control Unit part number?
MELOVEGN
Heater Control Valve part number?
Would anyone happen to know the AC part number for the stock Heater Control Valve??
Please help :)
Thanks guys
rich your asking about the part that is on the firewall attached to one of the heater core hoses right?
Hi Mike ,
Yep thats the one
Thanks for your help 1970gsx ill check that number out and see if thats it
Correct #
Originally posted by 1970gsx
The part # I have on my spare is 16034664. Hope that helps...
Is this the correct # for the heater control valve under the hood? The valve that goes in the heater hoses that attaches to the heater core.
Joe
I need the part number for the heater control valve, also.
I think the part# that 1970gsx refers to (16034664) is *not* the correct one -- he says "Sorry, I thought you were asking for the control unit in the dash."
I looked up a Buick exploded diagram-- GM part 25518895 is described as "heater control flow" but the picture corresponding to this part# is wrong.
Also, 25518895 cannot be found at GMPartsDirect, although that does not necessarily mean the part# is invalid -- rare parts are sometimes not listed on-line.
Bottom line, I'm not sure what the correct GM part # is.
Kirban sells the Delco metal heater control valve for $34, Kirban part #6594.
Read somewhere that GM also offers a plastic valve version that is supposedly less likely to corrode & leak, but haven't been able to confirm.
Good number Brian
I got that number somewhere too
i just ended up not having to replace mine but that should be the number
