Hot Air Beast
Hot Air Lover
- Mar 10, 2007
After a good outing and a half hour drive home i parked the car. It was running fine. It sat for a day and I tried to start it a couple of hours ago. NO GO. I could not hear the fuel pump so i checked for power to the fuel pump - NONE present. I checked the fuse -NOT BURNT. I checked the schrader valve at the rail -NO PRESSURE.
I am a low tech back yard mechanic but i can find where things are and look for simple solutions like broken wires, bad grounds, cracked vacuum lines and the like. I have no tools down here in Florida. Looks like I will need to be towed to a garage. Not much luck with the last one down here.
Any suggestions as to what i could check before getting towed to a GM shop??
