Im New Here And I Have A 87 Gn With A Stage 4 Turbo, And Front Mnt Intercooler, 3inch Down Pipe And Exuaust, Ported Heads, New Walbro Fuel Pump, And Hot Wire, New Fuel Filter, Dfi Ignition, New Coil, 42lb Injectors, And Art Carr Modified Trans, With Line Lock. I Just Bought The Car In The Spring And All This Work Was Done In 1999 By Turbo People Of Ny Then The Car Was Parked And Driven About 5000k Since Rebuild! Ok Heres The Problem, I Was Driving Stupid And Donig Burnouts When Out Of No Where The Car Started Missing And Breaking Up Under Any Boost. Driving Normal And Ideling The Car Still Ran Perfect But As Soon As It Hit Even 5lbs Of Boost It Would Studder And Break Up! I Had A Fuel Pump And Filter Installed And It Went Away!!! Then While At E Town First Pass With 17lbs Of Boost The Car Ran Flawless! 2nd Run I Turned Up The Boost (not Sure Exactly How Much, But Wasent Alot) While Shifting From 2nd To 3rd The Trans Slipped And The Motor Overeved Then Shifted And The Missing Came Back!!!! I Drove The Car Home 2 Hours And It Drives Great If You Dont Floor It, As Soon As It Hits Any Boost It Misses And Breaks Up, If I Turn Up The Boost And Drive Hard It Pops And Backfires!! Sorry For The Book But I Have No Idea Were To Start And Funds Are Tight To Bring To Back To The Turbo People (plus They Seem Extreamly Busy) I Have No Way To Hook Up To The Dfi, And Was Also Wondering If I Should Convert It Back To Stock Computer With A Chip!! Help Help Help!!!!
