Help car killing
KCODE
I put a new up pipe and MAF pipe on my 86GN. Got rid of the BOV. Took car for a test drive sputtered and killed. Started back up sputtered all the way back home. On the BOV was a vacumn hose running to a t a hose on the fire wall of the vehicle. I replaced with a straight hose did I need that t and was it suppose b attached for a vacumn. Oh the hose is also has another t with a hose that is attached to the line above the fuel rail.
all you had to do was take it out like you did.
is your car sputtering while trying to idle?
No its sputters when I hit the gas then goes.
