So I just rebuilt my motor got it all in the car hooked up and turned the key.. was so nervous I almost threw up haha
. So it turned out great cause it started after about 2 cranks and had perfect oil press. and coolant temp. we got it to idle a little better and the fuel pressure is about at 39lbs or so. Here is my problem, its smoking... I had put a gasket between the turbo and the exhaust manifold to attempt to stop any leaks and well it got fried so I thought it was probably that smoking. I took the turbo off cleaned it up nice and put it back together. Still smoking. Its not purple oil smoke and its not that really bright white coolant smoke either. Its like a dark white grayish almost and smells like a chemical burn. Not like the usual burning fluids smell. When I did my piston rings I did a chrome moly type speed pro set. I broke one ring and imediatly replaced it with an identical one. I double checked all my other rings and they were all staggered right and all in tact. The pistons I installed are speed pro forged aluminum .040's and they were brand spankin new when I put them in. What could be causing this smoke? I had the heads ported and polished could it be the cutting oil they used burning off maybe. A residual? Had a complete valve job done and my machine shop guy, who is one of the best in colorado for TR's, installed brand new seats and stem seals. Could it maybe be a coating on the pistons that will eventually burn off? anyone else had this problem? Maybe some residual oil on the cylinder walls or rings from when I installed? Please help I am very frustrated.... Put alot of time and money in this car and dont wanna pull that motor again. Thanks in advance
-Andrew
-Andrew
