XxDarkSidexX
Banned
- Apr 4, 2002
View attachment ideling warm small revs 5-21-08.zip
This is a first for me, so please bare with me. So I finally got my car running after 2 and half years! I got a FAST B2B unit and used a shared startup file to start her. She idels okay, a little high on the rpm side. I couldn't get the Actual AF to match the Target AF during idel, so if anyone could help me out with that, it would be great! I let her run up to normal operational temp according to FAST my china radiator works and is keeping the temps in the 150 range (it was about 98 degrees out when i did the data logging in my garage with the door open) and then I began data logging. My question is how does this idel look? I had emailed CAL and pm'ed so maybe he is just busy, that guy is all over the place helping others so I am not really tripping. But I am ready to change my tranny gasket/fluids and install my boost controller, when those are done I will go for my madien 1st drive! So can anyone take a look at my log and please feel free to comment or give any type of information in response to looking at my data log.
I will data log more if I need to, if my settings are way off or my file isn't looking normal here is some info for any FAST vender out there who can make a correct program to run before I hit the dyno!
Let the fun begin.....
235 motor
girdle
JE's
.010 over stock crank
stock rods
GN1's full port n polish, 1.55
matched port stock intake
razors dual alky
340 pump
83's inject.
36-3800 stall Art Car
T66 dbb
3.5" DP no exhuast yet but will run a dual 3" stainless setup
XxDarkSidexX
235 motor
girdle
JE's
stock rods
razors dual alky
340 pump
83's inject.
T66 dbb
XxDarkSidexX
