This is insane! I cant find any local parts, hardware, or hydraulic supply stores that have the right size steel flare fitting for the end of the brake lines where they enter the master cylinder. Particularlly the larger (1/4") line at the front of the master cyl.
Anyone know of a source? I'm probably going to just obtain a line from a friend and replace the whole thing. I had to cut the line, and have to much straightening to do without kinking it, in order to put a new fitting on and flare it.
That means if I had this much trouble with getting the nut out of the master cyl, it'll be even more difficult to get out of the proportioning valve. I'll just tube-cut it at the valve and use a 6-pt socket to back that one out without tearing it up as well.
What a simple job turned into a nightmare. All for some stuck fittings that cant be found anywhere.
TIA
TIA
