tt455
- Apr 15, 2022
I know this has been talked about often but I still need advise. I posted three videos so maybe if other people have this problem it will help them also.
I have a video of my numbers and then pressure with key on and then running at start up. At start up she did finally shut down it's a little noisy but does quiet down later.
With key on I was only at 20psi but after rapping on filter and regulator I got more like 30, but drops quickly as seen. At start up it's steady at 40+ but almost sounds like it's starving for fuel? If I feather the throttle it will eventually run but does stutter irregularly and stall. I'm thinking first changing the fuel filter and then possibly checking or replacing regulator, pump relay? Or is there a leak down? I'm not sure but this is the usual things that I read about in the threads.
This is what I know of the build which was done by previous owner.
87 Turbo T WE4
rebuilt about 5k on engine
206/210 roller cam
roller rockers lifters
arp studs 20 over
crank rods 10 under
rjc pullies
ken bell air dam and intake
340 fuel pump hot wire
new sending unit
Art Carr built trans
3" single exhaust
87 Turbo T WE4
206/210 roller cam
arp studs 20 over
crank rods 10 under
rjc pullies
new sending unit
3" single exhaust
