help!!!!!!!!! indentify these injectors
buickbert
ok here we go, i bought a set of injectors that had been flow tested and matched, they were supposed to be #38 injectors. they have a green stripe on them and have the numbers 621037, and 03165AA, and a funky eye looking logo on them, is this what they are? #38's?
also the ones that i took out of the car were in there when i bought it, they have a 650, and 927, and 0 260 150218 on them, no stripe on them? could they be the factory ones? anyone have pics of stock ones? the car had some mods on it but not too many engine mods done to it.
ive attached a link to the photos so you can see them for yourselves.
http://s84.photobucket.com/albums/k11/buickbert2/?action=firstLogin
thx
buickbert
Quick google search:
Delphi / Lucas
37 lb / hr. Disc Injectors
Part Number Delphi D3165BA (Lucas old 5203002, Lucas New 621037)
Static Flow Rate: 37.27 lb/hr @ 43.5PSI (300kPa) or 282gm/min
Dynamic Flow Rate: 8.42 gm/pulse - 2.5ms pulse width and 10ms repetition rate
Coil Resistance: 15.9 Ohms / High Impedance / High-Z (No ECM driver modifications required)
Additional Information:
Top feed disc injectors use a small disc with six holes around its circumference. The disc rests on a short chimney that surrounds a metering hole. As the disc is raised off the chimney by magnetic force, fuel flows through the holes in the disc, over the walls of the chimney, and out the metering hole to form a full, finely atomized cone.
Performance advantages over pintle injectors (i.e. Ford / Bosch & Accel types) as listed by Delphi:
• The flat mating surface ensures that no excess fuel is present to evaporate and therefore, no deposits or clogging can occur.
• Compatible with alternative fuels (i.e. Methanol)
• Longer service life
• High-speed disc action allows wider dynamic flow range for improved idling
• Quieter operation
• Revolutionary disc design resists build up deposits which can affect fuel flow.
• No Fuel leakage for quicker starts
thx man, now i know for sure what the green stripe ones are, anyone else know about the others? stock? got numbers and pics of the stockers?
thx
buickbert
