12.30@110mph, 1/8@7.99 ,89mph. 26 BF/DR, leave at 5psi, 1.9-60ft. O2s 759 at the trap, kinda fat thru 1st/2nd. Is this right? My TE44 ran better with blue tops!!!
SignUp Now!Im running TT chip(alky) timing 26/21, trap RPM5400, LU 3000stall,26''BF_DR,Boost 20-21.What chip are you running?
do you have any logs of the run?
What was the RPM as you went through the traps?
this is a Non locking convertor???
the 26" tires are helping much either....
What is your boost level and timing?
there are a lot of holes in your info to give you any advice.
I just saw this reply, but yes i go to jackson dragway as much as possible, but i work 3rd shift. I took the car out tonight, and i did away with alky, but i added 4% fuel at WOT, the car did a 12.44@112mph, the O2 thru 1st, and 2nd are 894-850, then at the end of the trap its down to 731, im launching the car easy, and running 20-21 psi. I dont think my boost guage is right, and how do i make it drop in fuel on launch(build more boost?) Also added timing in 1st/2nd @27, 3rd @21. Fuel psi at rail is 45psi!i live pretty close .i think you should be running alot faster.1/8 and 1/4 mph looks to be slow for your combo.pm me maybe me or friends of mine could meet you at the track sometime to work the bugs out.:biggrin:
Thx for info, so i can subtract fuel in 1st, then add fuel to all gears? Will tuneing with a lap top, help that much? I have no idea what to do with that.
Ok, i put chip back to where it was, and it ran alot better, Mid 700 in 1st/2nd, and 750 at trap. I add 2points in timing in 1st/2nd that lean it more. Now i cant build boost to 5psi without spinning tires, but the car has great hydroboost brakes. It seems to like T/C lockup, but i got to figure how to make it lock without lifting up on brake pedal, if i adjt switch on pedal to come on, the car dont drive good in normal driving. Do i need better tires, i have 26 BFG. The car is still only getting 107-112mph, with a 60ft of 1.8-2.0, how much boost do you need to leave with to get better Mph? Oh chip is made for 22/20 timing-20-24boost, but i bump it 2point in 1st/2nd.
Boost is at 20-22, but i think my gauge is off. timing is 22-20, and launch at 5lb, octain is 110.Your launch boost has absolutely no effect on trap speed....launch boost has everything to do with 60' time and ET.... the trap speed is the HP indicator.... the ET shows how well you made use of your HP/TQ....
The torque converter won't L/U in 1st.... it is physically and hydraullically impossible..... you probably only need 5-6 lb launch to get sub 1.8 60' times....8-10 lb launch should probably net 1.6X 60' times....
As far as tires.. I personally hate BFG's.... I really like MT drag radials....and their ET streets... M&H racemasters hooked well for me as well...
On a decent track at your power level... some good drag radials should easily go 1.6x 60' with little to no suspension work..... so yes... I think you might could use better tires...
What boost are you at now?
What timing now?
What launch boost?
Depending on thos numbers... you might can increase boost.... or increase timing (but not both at the same time).... to get the trap speed up....
Also... what converter did you say you have?
What octane fuel?
What intercooler?
