Help! Look at this sad video of my T-Type
wv-t
TB guys, I need your help. Last weekend installed a Power Plate and the car has been running worse and worse until it deteriorated to the state seen in this video. Please watch until the end so you can hear the engine under the hood. The smoke and smells are bad.
You know, I am not blaming the Power Plate (and yes I did drill the EGR hole). I think that I may have messed something else up, though. Before I start throwing parts at it I want you guys to please analyze it. Thanks guys. 1986 T-Type almost all stock except for Walbro pump and newly installed Power Plate.
My car has never ran this crappy before. Not ever. :(
AF should be reading 4 - 7 = bad maf sensor. Is it stock original?
code 22 is low TPS signal, like already said set it to .42
Idle RPM's to high,most likely from the bad MAF sensor problem.
CC's to high
IAC reading to high, should be 15 - 25
Do you still have original chip? If so its got to go. The factory emission chips make our cars run terrible. Why your tps so low?
Thanks folks, this message board is worth its weight in gold at times.
