jarredsoon
- Aug 9, 2007
OK.
So I have a stock tta and decided to put a K & N airfilter on it, so I got one that fit onto the elbow and into the corner of the fender. I put it on.
So then I decided to put a breather on the valve cover on the drivers side. I removed the pipe and put a breather on the valve cover and took the pipe right off. the other end of the pipe goes into the inlet bell of the turbo so I put a cover on that.
NOw I can't get more than 5 lbs boost when WOT. WHat is going on. WHat did I do???
SO I take the breather off and re-attach the crank case vent pipe and hook it up between the valve cover and the turbo inlet bell, still no more than 5lbs boost.
What do you guys think?
Thanks.
Thanks.
