First time I have hooked up TL. I saved the idle info after the car had warmed up. Car runs decent, but seems to stumble low end.
Here are some of the numbers that seem to deviate from the normal values I have read about.
Idle values, car warm
TPS .36
o2 cross 0
O2 volts 738 mv
IAC index 0 # 0%
Car has a Thrasher 92 chip with FP set to 45 psi line off.
Do I need a new 02 sensor based on the cross counts? What is up with the IAC index? Is the TPS set too low?
Thanks,
Joel
(TL rookie)
TPS .36
o2 cross 0
O2 volts 738 mv
IAC index 0 # 0%
Thanks,
Joel
(TL rookie)
