GNregistry
- Apr 7, 2002
I would like to know why the vacuum brakes are better vs stock GN brakes?
I have brake problems and purchased Vacuum system.
Why do people switch and what modifications, pro's, con's of switching and what has to be done to replace vaccuum, I will not be doing it myself, but wondered is it small job, not sure how to explain what I don't understand.
I mean Buick choose the stock version of brakes for a reason... and vendors offer vacuum style. What work is needed? How much time is needed? How easy or difficult is it to replace stock brakes to vacuum brakes, and then if used while racing, what are the drawbacks, if any...
I hear the push for installing vacuum brakes...
Now I want to understand, is there a information out there to explain how it works and what is needed to convert...
Also, interested in new exhaust, stock dimensions, who has the best cat back exhaust, stainless steel vs aluminized, would like to install one time.
Using stock ideas, with TA49 turbo, for dependable street driver maxed to the limit... with out pushing engine into ground...
Brett
GNregistry@aol.com
920.279.5466
Brett
GNregistry@aol.com
920.279.5466
