witchdoctor813
- Mar 18, 2013
First off I dont have a scanmaster. The turbo doesn't seem to be engaging at all. Turbo doesn't have oil in inlet or excessive play. All help appropriated
SignUp Now!Well you said it sounds strange. Exhaust leaks will do that and cause boost problem.
Other than that the waste gate may be not sealing for some reason or the Turbo is worn or no good , bearing, etc.
Plugs look good? Do you try new ones
Installed new plugs
IC couplings separate?
How do you check the puck?My guess is the waste gate puck is stuck wide open and the exhaust is not getting chopped up by the exhaust turbine and the turbo is not building boost????
Have you popped the hood to look at it ?? Maybe someone LS swapped it lmao
Had that been the case, there'd not be thread # 1,010,101, asking WTF is wrong.Have you popped the hood to look at it ?? Maybe someone LS swapped it lmao
