turbo buicks
ESADAH!!!
- Jun 13, 2002
i know PAW carries speedpro/sealed power parts, edelbrock parts, comp cams parts and most any other maker there is. i found a 204/214 cam in the catalog and i looked it up on speedpro's site and looked previous posts with the cam's specs in it and compard them to the what the catalog says. the catalog says:
duration
intake: 262
exhaust: 272
duration @ .050
intake: 204
exhaust: 214
lift
intake: .448
exhaust: .472
is this the speed pro cam b/c i saw an old post about this cam, w/different normal duration numbers but the same duration @ .050 numbers?
here are the edelbrock specs from their site:
Duration at .006 Lift: Intake 280° Exhaust 290° Centerlines
Duration at .050 Lift: Intake 204° Exhaust 214°
Lobe Separation: 112°
Lift at Cam: Intake .280 Exhaust .295 Intake Centerline: 107°
Lift at Valve: Intake .448 Exhaust .472
why is their duration @ .006 differnt than the PAW 204/214's but the same as the PAWs 214/224?
simply put, what 204/214 cam do i want to get (speedpro, edelbrock, etc?) and where can i get it. PAW has cams for $50 and for $85 you get the cam w/lifters but if this is the wrong cam i wont get it. what cam maker makes PAWs 204/214?
thanks
duration
intake: 262
exhaust: 272
duration @ .050
intake: 204
exhaust: 214
lift
intake: .448
exhaust: .472
thanks
