Help My Girls 84 Gn Is Having Problems
87gnand00ws6
Hi. The car recently went in to repair a blown head gasket. The headgasket was replaced and stock size rods were used. the heads had to be milled because of warpage. after we got the car back it ideled really high for some reason, and continued to idle really high, until now it wont even start. it starts for a second or so and burps off. i checked the maf and its fine, map sen is new, so is the tps. Idle air motor is new as well . any other thoughts. could the push rods cause this? whats the deal.
Hi.
Sounds like they might have milled to much off of the heads. If they did and did
not mill the intake manifold to match you could have a vacuum leak,which will
make it idle fast just like having a vacuum line off. Just food for thought!!!:(
