ChevyIIMan
- Apr 27, 2005
Hello... I need help on finding out the origin of this turbo. I was told it was an 84/85 Riveria T-Type Turbo. The Comprosser Housing matching everything ive seen of Hot Air Cars but the Turbine Side is where I get lost. It does not look like the GN pictures I have seen. Nor does the Exhaust Elbow.
The exhaust elbow exits 90 deg from the orientation of the exhaust inlet which what i say the GN ones exit the same direction.
The Compressor housing is stamped with a .60 on the inside of the outlet and the Turbine as you can see is stamped .82.
Any info on this turbo would be greatly appreciated.
