I have a question or something that I have noticed about the target pressure of 30-35psi on the low side and the 280psi on the high side. Yes, I have found these numbers to be accurate per and are straight out of the GM Turbo Regal Repair manual (See attachement 1), but those numbers are based off of R12 refrigerant. Since R134a operates at "almost" twice the operating pressure of R12, shouldn't that make the GM based manual not applicable for R134a retrofits?
I also found the "Performance Air Chart" in the manual (See Attachment 2).It states that @ 90 degrees F , the air discharge is 36-43 degrees F (thru vents), 200-245psi on High Side, and 26-35psi o low side.....which is fine for R12.
Now for R134a, the chart shows (See attachment 3) that the manifold gauge on the low side should read 45-55psi and 250-270psi.
Should I use the R134a chart numbers or the R12 numbers from the GM Manual (Even though I am using R134a)??????
