I just installed a Racetronix G7 sender/Turbine Tech 255LPH fuel pump combo and I can't get fuel pressure. I made sure I put the hoses on correctly. I put about 6 gallons of fuel back in. I turned the key and can hear the pump prime. I really think I did everything right but I cant seem to get any fuel pressure. I took off the fuel filter to see if gas would come out of the line when it primed but not a drop. I dropped the tank again and checked for kinks or pinched lines but all was perfect. I tried swapping relays. I kept priming it over and over. I tried cranking it and still no pressure. I don't know what else it could be other than a defective unit. I can hear it prime. I have the hoses on correctly where they go. Its like the pump isn't picking up fuel. Maybe I should add more gas?
