Two nights ago, I left work and decided to "exercise" the GN on the highway. Well as soon as I got off the on ramp, i primed the alky, hit it to about 1/2 throttle when all of a sudden the car sounded like it backfired, started sputtering and died
. I was able to turn onto a side road to see what was up. Opened up the hood and could not see anything out of the ordinary. All vac lines, intercooler hoses in place. Checked under the car for any leaks, etc...nothing. I tried starting it back up and all it wants to do is crank...no start. Had a buddy trailer me home so I could diagnose it.
Here is what I have done so far: checked coil and have spark (coil and module are 1.5 years old) , put a noid light to the injector harness and it flashes (crank sensor should be good), changed fuel filter and fp relay. When the ignition is turned on, I can hear the fuel pump running as it should and my fuel pressure gauge is on 40 psi. Is there a possibility that the cam or crank sensor is bad? Any suggestions would be appreciated. I hate to start buying parts without knowing what exactly is wrong.
