Squid4life
- Jul 5, 2004
HEATSEEKER said:I think i found the problem, the kit is working but not under boost i think so it most be the map sensor, i have GNX gauges so i have to do some new wiring.
Can you explain and maybe show me some pics off the TPS switch,
There are wires on the map contact now, should i cut all the old wires on the contact and start whit new from the TPS switch?
Thanks!! / Jakob
If the alky is spraying with the test button, but not coming on at boost, then yes, you have an issue with the MAP sensor wiring. Don't just cut the wires and start over though. Just tap into the GREEN wire at the MAP sensor, or under the dash behind the glove box, or behind the dash cluster/gauges. The green wire runs to the alky kit and triggers the system to spray at boost. Don't worry about the TPS switch if the car is running and it is set at .44 volts at idle, 4.6ish at WOT.
