ChrisCairns
Senior Member
- May 24, 2001
K....I'm reinstalling the overrun assbly/shaft and pump. I've put the overrun assbly in the case and now must put the overdrive clutches/steels in. According to the video I'm following they state its....
Steel, clutch, 2 steels, clutch, thick pressure plate.
According to what I took out and originally was put in by Len (not available for me to ask right now) its....
Steel, clutch, steel, clutch, steel, clutch, thick pressure plate.
So I'm wondering if tranny builders stick a clutch in between the 2 steels where the video says theres 2 steels together? Or is the video wrong?
I'm trying to get this together asap so if anyone knows and can answer please do so tout suite. (Right away in French.)
Thanks so kindly.
Thanks so kindly.
