onefastjackass
- Oct 6, 2002
OK I am doing the 400 swap and need to know what dipstick tube you are all in favor of using.
Tryed a summit chrome one and the bracket didn't want to line up even after bending.Tryed to use a lokar one that mounts to the engine but it would be almost impossible to remove it and check the fluid.
So what are you guys using??A lokar firewall mounted one or something else???
Also If the transmission is a regular pattern and uses a vac regulator would I just hook it up to engine vac or is this going to cause issues since part of the time the engine is under boost???
