Scott89TTA
- Jul 12, 2005
A little info 1st...I'm a complete noobie on these turbo cars and have a ton to learn. I have messed around with cars since the 70's but this is all new to me. I do have a Scanmaster and must admit I pretty much have no clue as to what I am looking at most of the time
We had some nice weather so I pulled the cover off the TTA to take it for a drive. First the battery didn't have enough to start so I jumped it and she started up...hadn't been started since late October. Once it warmed up I shut it off and restarted it a couple of times and it seemed fine. I took it for a short drive and all seemed fine. So I took it out Friday night to meet some local car club friends. Several times while getting on it pretty hard it sputtered and seemed to pop or backfire ? It did this a few times back in October before I put it away for a few months. Now the only thing I have done to the car is add a "Grumpy" MAF pipe and big K&N filter back in Oct. Ever since it has done this on occasion. It also did the same thing right after I purchased it back in May and turned out to be a bad alternator...was only putting out around 11 volts. So now looking at the Scanmaster I'm seeing 12.7-13.5 volts...seem low to me shouldn't I be around 14 volts? So not sure if I'm having problems do to low voltage or something I have wrong with my MAF pipe and K&N filter install since the problem started around the same time. Any ideas what is going on here?
Also by changing from the stock MAF pipe to the Grumpy MAF pipe and a large K&N open conical filter make the boost go up over the stock 16.6 psi ? I ask this because I swear when this thing is running right and it doesn’t backfire the boost looks like it shoots up to around 18-19 on the stock boost gauge. What is a normal reading on the Scanmaster for a stock TTA during hard acceleration (Deg. Retard) ? I hate to admit this but what exactly does knock sound like
Here is the current setup I have.
Any help would be greatly appreciated.
Thanks,
Scott
Thanks,
Scott
