Hey guys,
I tuned my setup w/ the inlet air temp sensor not plugged in, and it runs pretty good, but when it's cold out, it runs rough. So I plugged in the sensor today and started to play w/ the VE map. When I plugged the sensor in, eveything leaned out, I had to add about 11% to get the 02 correction down to where it should be. Now, after driving around for awhile, the numbers kept fluctuating, sometimes I would need 0% O2 correction, then I would need 15% at the same RPM and same MAP (kpa).
When the air temp goes up, the engine needs more fuel, right? When you guys tuned yours, what are your ATS enrichment #s?? It was pretty cold out today, so I don't know if I'm tuning w/ it at a certain temp, then I stop for 5 minutes and the temp changes that much for the air/fuel ratio to be way off. If I have the air temp enrichment at 0% all the way across the board, does the sensor still have a role in the amount of fuel the motor gets??
I'm puzzled on what to do. Any tips and/or suggestions would be GREATLY appreciated.
Thanks.
Thanks.
