First off sorry for the length of this post but I am getting UPSET with the car...
I got the car listed below in my signature in late Fall last year. Ever since I got it, it has fallen on its face at WOT. If you ease into and do not FLOOR it then it builds boost (set at 15-17 manually adjusted and verified thru boost gauge) fine and pulls good but I KNOW that there is lot I am missing without being able to floor it. (i.e. ALOT FASTER) I figured it was falling on its face because of running out of fuel when I got it and installed the XP pump, billet FP regulator and got a new 93 street chip burnt by Red Armstrong (Quad Air). Set FP @ 43 lbs with vacuum off. And same problem. Put new AC wires and CR42ts plugs gapped @.035 in it, set TPS to specs, new Bosch 02 sensor and same thing. Then I put it up for the winter.
3 weeks ago I got it back out and changed the oil and filter (Mobil 1 10w30 and AC Oil Filter) Drove home from work one day CEL came on and it wouldn't pull itself out of a wet paper bag. Pulled over and pulled the codes (paperclip) and got a code 42. Then I started it back up and CEL was off (without resetting ECM) and it drove fine the rest of the way home. I was told that 42 was the ESC Module, so I put a brand new AC one on it. When I changed the ESC I noticed that when the prior owner swapped out the Powermaster brake set up he disconnected the PCV hose to hook up the power booster line and just had it hanging there so I put a new AC PCV on it and tapped into that vacuum line, but... it still falls on its face at WOT.
I have not checked FP at WOT with gauge taped to windshield but I plan to borrow gauge tomorrow and also borrow the same guys Snap On Fuel Injector cleaner (the one that taps to fuel rail and uses air compressor with mix of cleaner and gas mix) because I read injectors could get dirty fast with bad PCV (or one not hooked up!)
Any other places I should look? oh yeah, ECM was recently replaced before I got it, it has a newer ESP coil pack on it but I haven't check ohmage on it yet... It has 125,000 on stock long block but valve springs were supposedly changed 10-15000 miles ago. What else should I check or do, I am dying over here!?
Thanks alot and sorry again for the long post!!
Eric
Eric
