Hi Redd,
This is probably a good time to refresh this thread:
http://www.turbobuick.com/forums/ge...-rear-into-tr.html?highlight=independent+rear
Since six years (+/-) have passed since the posting of this thread, not all of the data may be up-to-date, but I'm sure at least the bulk of it still applies.
Some basic points:
1.) An IRS swap will add weight to the car, not subtract it. The weight savings occurs only in the realm of unsprung mass.
2.) An IRS has limited (perhaps 50%) anti-squat.
3.) You'll probably have to go back to C4 or older to get an IRS that's narrow enough to fit in a G-body without undue modifications.
4.) You'd better be a seasoned ace fabricator to make the swap. Expect absolutely everything to require modification/adaptation to work in a G-body.
It wasn't long after I started that thread, that I came to the conclusion that the best overall solution (cost, complexity, benefits) to the handling/traction problem was to use a 3-L rear with Panhard rod. Apparently Ford came to the same conclusion with their latest generation Mustang.
And one of these days, I'll actually find the time to do it...
Best,
MAP
