HELP What could be wrong????????????
Buickcruiser
Hey guys,
My ECM got damaged and I purchased a replacement. I installed it and my vehicle still will not start. I hooked a volt meter to the injector harness and the injectors are not receiving any voltage. I also hooked up my turbo link and it is not showing an ECM. But, the amber light on the dash is coming on. I am getting spark but just no fuel and the turbo link can’t receive data from the ECM. Would you all have any idea what is wrong with my car? Could my chip in the computer have gotten damaged? Any help would be greatly appreciated because my car is parked in front of my house, and we don’t live in the best neighborhood.
Thanks,
David
:confused: :confused: :confused:
If you tell everyone what actually happened to damage your ECM - how it happened, someone on th eboard will probably have a good idea of how to help you.
Ok Guys
I feel like an idiot. Here is what happened. I pulled my car out to change the brake pads on my truck. When I went to pull it back in the car would not start. So I jumped it and it started and as soon as a pulled the cables off and went to put it in gear it stopped. This happened a few time and I was getting real frustrated. I grabbed the cables one last time and crossed them. :mad: Once I got the new ecm switched the chips checked all the fuses one 7.5 was blown under the dash and a 7.5 on the orange ecm line. I went to jump the car and it started I wasn’t going to try running around again so I waited for friend to come over so I could be in the car giving it gas to prevent it from dying. When he came over it would not start. So I pulled the alternator took it to auto zone and it tested fine so I got a new battery. I am very knowledgeable about car but made a stupid mistake.
Any ideas??????
David
If you crossed the cables the chips that you swapped in the ECM may be bad. I know that when i replaced my ECm i had loose wires and the car would not start so check to make sure that your wires are tight and check to see if you rchips are still good check your fuzable links and things in the engine compartment to make sure it is all in good shape. I crossed the wires on a cougar once and wiped out the whole Electrical system so check everything you can think of on that harness. Good luck and i hope you get her running. Harry
Hey guys
OK I checked several things. First both sides of the fuse is around 12. The fuel pump is working fine my FPG is @ 20psi. I rechecked the injector harness and it is showing .03 with the key on and .25-.50 while cranking. I checked two different plugs and they both showed the same thing. For some reason my turbo link is working now. So I go some data off of that.. The only thing the really pops out is the mat temp is 86 then –58 when cranking. When it goes to –58 the block learn goes from 128 to 0. MAF is showing 4 GPS and the injector PW is 0 and 7.2 and 15.6 when cranking.. and the 02 volts is 414-515. Also I was going to check the cam sensor with the casper tool do you have to move it for the led light to come on or should it come on with out adjusting it if it is set right.
David
:confused:
Woops
I meant to say 30 psi. actually around 32-34. This is with the hose on. I know this is a little low I have a new fuel pump that I need to install once I run some of the gas out. How do the other numbers look? Could the mat be bad?? And do you know if the light should be on with the cam sensor tester.
Thanks David
ecm problems
Just a quick question. Did you change the calpack chip out of your old ecm into your replacement ecm?
Hey Guys
For some unknown reason I got my car started it is running like crap but it started and I was able to get it into the garage. That is a big relief. :D Now I need to why it wasn’t running and why it is running so bad. To get it started I looked under the car and checked to make sure the crank sensor wasn’t damaged and hooked the injectors back up. I cranked it a few times and it sounded like it was closer to starting and about five trys later it did. What exactly does the crank sensor control and could the sensor be bad without being damaged? Is there any way to test it?
Thanks for all of the help
David
