I blew off the line to my MAP sensor and leaned out .Now the thing runs fine in the water box and will run up to 7200. But when I try to make a pass it hits about 6300 and starts to flutter and will not pull any higher under load.It doesn't seem to have any blow by and everything looks good on the speed-pro.I've changed plugs ,wires,coil and module but no change.Is it possible it is a bad head gasket ?I've blown a few on the stock block but never on a stage II block.Can they act like this and not spew water out ?
