help with B&M tranny cooler wiring
TheYak
Hey guys, need some help hooking up my tranny cooler. Yes, i lost the instructions :redface: It's the one with the fan and 160 thermostat, someone has to have one here. (B&M 70297) Any help would be appreciated! Thanks in advance :cool:
I have the same cooler. As soon as I get home from work I will get out the instructions.
Where di you mounts your? I had mine under the stock IC fan, I have a FM. The cooler sat horizontally near the front sway bar. But I broke the temp sensor on a launch when the sway bar swayed.
Hope this helps. Drew it right from the instructions.
Mine's mounted right between the air dams at about a 45 angle, i also have a front mount. I'll check it for clearance later, thanks :)
Twiny, thanks alot for the info! I appreciate you going out of your way to draw that up, i'll hook it up this afternoon. Thanks again !!!
Not a problem. Just do me a favor, post up some pictures of how you mounted yours. Mine is not mounted yet because I haven't gotten my car back.
Took some pics, couldn't figure out how to post them. PM me your e-mail and i'll send 'em to ya. Sorry!
