UR50SLO
The Reaper
- Jun 12, 2001
As our two similar Camaro saga go's on... we have noticed that the one Camaro with a TTA style Terry Houston DP that makes a very sharp bend just off the flange to turbo has a harder time spooling than the other car with a Buick Style Terry Houston DP that makes a less dramatic turn and attatches to a 3 1/2 inch down pipe from there down...
Anyone had similar results with running different down pipes with larger turbos such as the .72mm {PTE}
Under light throttle and minimal boost 5lbs or so the TTA dP car flutters boost... .
Under light throttle and minimal boost 5lbs the Buick DP car is steady and very responcive... Sure seems like DP to me.
Thanks for any input guys... ~Scott~
		 . Now I can't tell ya the dp isn't suspect, but have you messed with the tune? Seems like I've heard people say less timing will make ya spool faster? Tried that? I wonder if maybe richening it up would help?
