Help with DS file
bullet87
Can anyone make heads or tales of this. Im using a ME 16pos chip with 83 siemons. This was only at 14 lbs boost. Im working on the TPS problem.
Did you lift?.
How about explaining what you were doing in the file, and what the problem was.
description
no lift, rolling from around 40. Going down the road. ME pos was on 6. @ only 14lbs of boost this seems ridiculous to be getting this much knock. Maybe my plugs need to be brought into around 42?
Then you'll need to fix the TPS, before you do anything.
brought into around 42?, you lost me on that one.
42 spark plug gap. I going to work on that now, should be able to post another run in about an hour.
yeah 0.32, now that I got the WOT TPS at 4.64 and the IAC @ 30 and I think I heard my knock sensor go off letting me know that it works, finally. I can't get to keep from over boosting. I hate those damn adjustable regulators. I will try again today.
