I need some help with a problem i am having with my hydroboost on my 84 Turbo-T. I replaced the old hydroboos that was leaking with a rebuilt one. The problem i am having is with the brake part not the powewrstearing part. When i press on the break the pedal feels soft untill you get about half way then it feels like the hydroboost sucks the pedal to the floor and stops and wont return till i turn off the engine then the pedal returnes back to normal. With the car not running the brake peddal feels soft. The hydroboost has 3 hoses going to it 1 high pressure that is screwed on and 1 low pressure that is also screwed on and 1 low pressure that is just a press on fitting. Any help would be good it is my daily driver so it cant be down for long.
Thank you JOHN
Thank you JOHN
