KILL4PEACEUSMC
Team Infidel
- May 7, 2007
Hi, I bought a Wolfe anti-roll bar from a fellow board member, but now I see that having ATR 3" over the axle dual exhaust next to impossible to install this setup. So I got on their web site and did a little digging and under FAQ I found this helpful hint: Can I run full exhaust with a Wolfe Race Craft Sway Bar?
Yes, you can. Some cutting and re-welding will be necessary. We have seen 3" exhaust installed with our sway bar on both a Mustang and a Buick GN. What normally has to happen is your exhaust will have to be cut and twisted to clear the sway bar and then rewelded. This may require multiple cuts to fit properly, but it can be done.
Im not sure I want to butcher up my killer exhaust system. Any sugestions??
