Ok, my dad's 1989 camry failed emmisions. We changed the spark plugs, distr. cap and rotor, pcv valve, and installed a new muffler (the old one had a small hole in it). The air filter was clean. We even put that "Gauranteed to Pass" additiive in the gas..
We took it back to the inspection station and nearly the same readings happened again (high HC and high CO, the NOx was ok though). Does anyone here have any clue what the problem may be? The car runs fine..
Maybe the oxygen sensor? EGR valve? Injectors clogged maybe? I dont think that the catalytic convertor would have anything to do with the high HC...
