I'm having a problem or at least I think I'm having a problem with excessive converter slippage in high gear and wonder if anyone else has gone through this or has an opinion.
I'm running a TH400 w/brake and a PI Vigilante converter(non lockup)that they said is approx 3000 stall which is irrelivant becuase with the brake I am leaving at like 4000+rpm's(15+ pounds of boost) - does that sound right?
Now my concern is my rpm's through the traps and the fact that I'm getting around 21-22mph out the back.I was told I should see around 25mph which should put me in the 118-120mph range.Problem is I'm turning 5200-5300rpm's at 116.xxmph when I should be closer to 122.xx at those rpm's(with a 7% slip factor).Keep in mind I have 3.08 gears and have yet to run anything more than a street chip and pumpgas because I'm afraid of running out of rpm's if I switch to racegas.
Here are my two best runs:
60ft - 1.578
330 - 4.668
1/8 - 7.290@93.02
1000 - 9.575
1/4 - 11.517@115.52
60ft - 1.586
330 - 4.671
1/8 - 7.285@93.27
1000 - 9.564
1/4 - 11.498@116.19
Now,using this website http://www.smokemup.com/auto_math/mph_range.php I've figured out that my converter is slipping like 12-14% in high gear - which to me does not sound right.What should a properly built converter slip?I was told 5-7% max.I have already sent this converter back to PI and they tightened it up a bit(brought the slip down from approx 17% to 12-14%)and I picked up two mph and went from a best of 11.78 to 11.49 so I think I'm heading in the right direction with this.
Sorry for the long post but I'm not sure where to go with this and have lost my faith in PI - but don't know where to go from here.I have heard alot about Neil Chance,anybody using one of his?Any other suggestions?
Thanks in advance,
Steve
60ft - 1.578
330 - 4.668
1/8 - 7.290@93.02
1000 - 9.575
1/4 - 11.517@115.52
60ft - 1.586
330 - 4.671
1/8 - 7.285@93.27
1000 - 9.564
1/4 - 11.498@116.19
Thanks in advance,
Steve
