help with trans diagnosis
38turbo
Took off from a stop sign about 3/4 throttle got to about 15 psi and heard a quiet clunk. Rpms went up now trans has nothing all gears act as netural
Thought for sure I brke the stator shaft (stock trans). So I pulled the trans
Stator shaft is fine I didn't check pressure or anything before I pulled trans
Will the forward drum breaking cause all gears to act as netural also
Or should I be looking at pump and convertor
Thanks for any help
Matt
Thanks that's what I needed to know
Any special tools needed to change forward drum
I'm saving to have a trans built but would like to be able to drive until
I get the money
If you've rebuilt a tranny before then you're fine, if not then take it to someone.
