help with what conectors go to what injector. Need to fix today
85_Riv_T
Just a 4100lbs T-type
How can I tell what connectors go to what injector? The car is running ruff right now so i would be able to tell like that. Any ideas?
The injector plugs should have the numbers molded onto them so you know which injector it goes to.
If you can't read the numbers, find a wiring diagram....it'll show you which color wires on the injector plugs go to which injector. HTHs.
Durrr, I don't know how to read a diagram. Heres how they go
1 - black
2 - black/green
3 - black/pink
4 - black/red
5 - black/white
6 - black/yellow
Each paired with its respective brown wire.
Thanks for all the help. Hope the colors are the same since mine is an 85 Riv but I will soon see. (fingers crossed)
